1964 Polara 500 Electric window issues
64polara500Tom
New Member
1:44 AM
Clearwater
I have a 1964 Polara 500 hard top
It has electric windows, the driver side front and the passenger side rear don’t work.
Took the panels off and found the motors rusted out and stuck. Applies power and nothing. Got 2 replacement motors and found out that the switch from the 2 windows is NOT switching ground at all. Tested the switch works great. Took it apart and looked amazing inside and I still tested it out GOOD.
Is there a relay somewhere that I can test to see if it’s the reason why these 2 windows have no ground source?
A book I can buy to figure out where the wires go and what could cause the wires to not have a good switching ground signal?
Saw your post. I do not have an answer for your problem but I have a 64 Sport Fury and need two power window motors and have been unable to locate. Where did you find replacements? Any information would be helpful.
Thanks,
Jim
Search EBay until they come up, then take apart and rebuild them. Mine were so rusted i couldn’t and had to replace unfortunately
