R. Shackleford
Hey all, got a coupe questions about my poly 318 tuning. Engine has been rebuilt in the late 90's and currently has about 5800 miles. It has a 198-264 cam in it (unknown brand) with solid lifters and a Carter 4 barrel 9635sa (I know, I know, its a chevy setup carb that previous owner put on) on a cast manifold. It's been running good but a bit rich and a little rough idle, probably from the cam. Yesterday I went to tune the carb a little leaner. Ide mixture screws were out about 4 full turns from seat. I set them in to 1.5 turns to start and set the ide around 800rpm (roughly) and I noticed the timing mark on the HB was about an inch retard from the timing mark (not sure how many degrees that is). Now I'm not sure if that's set due to the cam or not. I advanced it to line up with the mark then went back to tuning the carb. Carb doesn't seem to like havin the mixture screws less than 3 turns out in order to smooth out a bit. Its not perfect but close. Then my timing light I've had for many years decided to die on me (leading to another question about whether it was working properly at all). I have another one sitting on my porch as we speak. I guess my question is with the 264 cam am I needing to leave the timing a bit retarded? Also the carb seems a bit off to be out 3+ turns in order to smooth out. This is my first Carter, I'm more of a Holly kinda guy. Any advice would be welcome. Thank you!
