SOLD 1966 Pontiac Tempest Restomod
nascar37
9:48 AM
Avon, NY
Feedback: +8 / =0 / -0
I am selling my 1966 Pontiac Tempest Restomod. The car is located in Avon NY 14414. The asking price is $69,995.
EBay Link:
1966 Pontiac Tempest Custom | eBay
Walk Around Video Link:
Here are the build details:
Fuel Injected - Resto Mod/Pro-Touring Build
Cameo Ivory White
Medium Blue Bench Seat Interior
488 Stroked Pontiac Engine
Built Turbo 400 Transmission
Power Steering & Four Wheel Power Disc Brakes
Protec-o-Plate and owner’s manual
Only 10 Miles on Fresh Build!
Paint & Body:
• Repainted in original Cameo Ivory
• Very straight bodywork and decent panel alignment
• I am very picky and have judged at car shows
o The body work is a solid 9 out of 10
o The paint is 9.5 out of 10
Engine:
• Fresh build with proper dyno break in - dyno sheets and video included!
o 544 horsepower – 616 ft. lbs. of torque
o 10.5:1 Compression – 93 Octane
• Original Pontiac 400 block
• Scat - 488 stroker crank, pistons and big block Chevy rods
• Butler\Comp Cams – billet hydraulic roller custom grind – 236/242 .521/.540 114 LSA
• Lunati roller lifters
• Comp Cams Ultra Gold roller rocker arms 1:65 ratio
• Edelbrock Performer RPM – Ram Air IV - round port cylinder heads
• Edelbrock Torker II Intake
• Holley 800 cfm Sniper Electronic Fuel Injection
• All ARP Bolts
• K&N air filter
• Canton road racing oil pan
• High volume oil pump
• High flow water pump
Transmission:
• Fresh built by J.W. Performance Transmissions
• BPO Turbo 400 long tail shaft case
• Custom 12 inch 2,200 RPM converter
• Full roller bearing sprag
• High volume finned aluminum pan
• Brand new SFI flex plate
• ARP Bolts
Rear End:
• Moser Engineering – Ford 9 Inch MusclePak
• 3:00 gear ratio
• Disc brakes
• Powder coating, fill and drain options
Wheels & Tires
• 17 Inch American Racing Torq Trust Wheels
• Brand new Bridgestone Potenza performance tires
o Fronts are 235/45/17
o Rears are 245/45/17
• Wheels were completely machine polished before new tires were mounted
Suspension & Steering:
• UMI Stage II Kit
o Adjustable tubular upper control arms
o Tubular lower control arms
o Adjustable front sway bar
o Tubular rear control arms
o Tubular frame braces
o Solid rear sway bar
o 1 inch drop coil springs
o Hotchkiss 1.5 Street Performance Series shocks
• Brand new Borgeson quick ratio steering box
Interior:
• Brand new Dakota Digital Dashboard with GPS speedometer
o Brand new ACC carpet set
o Matching ACC Custom Pontiac emblem floor mats
• The following components will come with the car to complete the interior restoration:
o New headliner and matching sun visors
o New dome light
o New rear view mirror
o New arm rests
o New door panels (on order will be delivered or shipped to buyer)
o New front and rear seat covers (on order will be delivered or shipped to buyer)
o New front bench seat foam
o New rear seat cushion material
Stainless & Chrome Trim:
• Front bumper is an original that has been re-chromed and shines beautifully
• Rear bumper is aftermarket and shines very nicely
• Rear window trim is new and in excellent condition
• Front windshield trim is new and in excellent condition
• Original front grill in excellent original condition (nicest I have ever seen)
• Headlight bezels are new and in excellent condition
• New arrow head hood emblem
• Side mirror is new and in excellent condition
• New drip rail moldings included with the car but have not been installed
• The post window trim is original and the aluminum shows some oxidation
• Tempest Custom side molding trim is in original condition – nice but some imperfections
• The fender and quarter panel emblems are brand new reproductions
• The rear “Pontiac” emblem is a brand new original NOS unit
Glass:
• Windshield is new
• Rear window is new
• Side glass is original and in great shape – windows roll up and down very smoothly
Under Carriage:
• The frame and under carriage have been painted chassis black
o Not concours finished but more detailed than a driver quality vehicle
• Complete Flowmaster American Thunder dual exhaust system
• Floorboards and frame are solid and rust free
• Brand new custom built drive shaft and yoke
• Powder coated tubular transmission cross member
• Brand new powder coated Holley Sniper gas tank with integrated fuel pump
• Brand new stainless parking brake cables
• Braided stainless transmission lines
• New fuel lines with proper heat shielding
Engine Compartment:
• Every component was replaced, rebuilt or detailed at the time of restoration
• Overall it presents with a show quality appearance
• Brand new Cold Case aluminum radiator with twin electric fans
• Brand new master cylinder and power brake booster
• Newer Interstate battery
• Hedman Hedders with custom ceramic coating by Jet Hot
• Brand new chrome 1 wire alternator
• Brand new high torque mini starter
• New pullies
• Shielded MSD Spark Plug Wires wrapped in insulation
If only FBBO member put that much pride and effort into writing their own adds, that'd be great! So would seeing the video!
Thank you, I have bought and sold several muscle cars from long distances and communication is key. I pride myself on ensuring a buyer knows exactly what they are getting.
I believe I have the video link corrected now!
Damn, that is a really nice car! And waaaaay out of my league, right now.
However, I can confirm that the video link works.
Remove my positive comment, Remove the others too.
