1968 dodge charger passenger front tire rub
Hi,
When I turn left, my passenger front tire rubs/bends in the passenger fender lip. It seems the passenger front tire is more forward than the driver front. What could be the cause? I recently put new disc brakes and tires so I am not sure if the issue is with the alignemnt or tire size. What is the max stock tire size that could be put on the front/back?
Disc brake kit moved wheels outward a little
If the only difference in measurements is the pass side is 1” closer to the front of the fender and the measurements to the rear of fenders is the same on both sides, it sounds like your fender wheel openings are not the same size. Have you measured the wheel opening on both sides?
