1968 Roadrunner Parking Brake question
JonnyBeervo
7:18 AM
Georgia
My 68 RoadRunner has a front disc brake conversion kit installed. The parking brake cable isn’t installed at the moment. Two questions. Does the parking brake cable only lock down the back wheels, or does it lock the front down as well? How is the parking brake cable installed with front disc brakes installed? Not sure if there is any difference.
Thanks!
A single cable attaches to the parking brake pedal, travels under the car toward the rear, then there is a bracket (equalizer) that two cables attach to. From there, the cables go to each drum brake assembly. So, yes, only the rears.
