1968 Runner post w/ 6.1L, 6 speed, IRS
I just came across this thread and looked carefully for some info.
What a great project congrats in its build.
But Could you please tell me, you refer back to "parts that I got from another SRT 8 this or challenger that.
How many cars did you part out? and how do you find these hemi 6 speeds to part?
I look all the time and only find clapped out automatics.
Ive bought 5 or 6 manual transmission Challengers at IAAI.com or copart.com. The manual cars are few and far between but they’re out there. Look at 09-14 model cars. I’m not afraid to buy some really damaged cars as long as it wasn’t hit hard right in the middle of the front bumper. I also stay away from fire and flood cars. Been there...tried that.
The Roadrunner came off the rotisserie for some panel alignment. The hood, fenders, and doors were all pinned for easy removal and reinstallment.
The 6.1L engine and TR6060 transmission are mated and on the RMS K frame. The engine is a 50K mile factory built short block. I added an Arrington cam shaft and CNC ported heads. The intake manifold has also been ported. From the factory it was rated at 425hp. It should comfortably make 500hp.
Holley wiring harness added
When are the 6.1 factory headers coming off?
They aren’t! The headers have been modified to fit. They are the Jeep 6.1L manifolds.
I don't like the taxi cab clusters so I went with a Charger rally dash frame bought the Dakota Digital gauges for 68-70 Charger. I rooted through my parts stash and picked out my nice Charger panel switches and cluster bezel. The bezel was redyed and came out pretty nice
I was looking through your thread and saw where you made your own core support stiffener. I am thinking of doing this myself and have a couple of questions. What gauge metal did you use? It looks pretty thick.
Also, did you cut out the old core support and weld yours in? The reason I ask is you fabbed up a completely boxed support so I assume you cut the old out and welded to the frame rails at each end?
Thanks
Lower radiator support needed reinforced and I didn't like any of the aftermarket options...
[/QUOTE}
