wtate
I have a 440 engine with the casting # 2536430 - 5, the casting date is 5-14-69. The pad on on the drivers side in front of the intake manifold has "F 440" then below it: "11 10HP".
My car is an original 1970 440 Six Pak car without the original motor. I'm wanting to put the correct motor back in the car (non-numbers matching) with the correct date, get it as close as possible.
My car was built between November 21st -November 25th 1969. I've heard that you should have a date that is no more than six months before the car build date. I'm wondering if this is true with block casting dates? I'm just over 6 months between casing date & build date. Also is the engine assembly date designated on the pad with the "11 10" November 10th?
Found this engine a long time ago and just want to make sure it's the correct one before spending money rebuilding it etc...
Any ideas on finding the original number matching motor would be helpful as well.
Any help here would be really appreciated.
Thanks,
Wayne
Thanks,
Wayne
