1970 Charger 500, 12v to 5v dash voltage limiter
G.V.Charger
4:03 PM
Grand Valley On.
No fuel, temp or oil presure, gauges, worked up till a couple of months ago. Does the dash, have to come out, for access?
It's obviously easier if it were out, but no - folks have been successful in doing it "in-car".
Helps to be young and limber - and have skinny fingers. :)
This is the site.
RTE limiter - rt-eng​
https://www.rt-eng.com › index.php › RTE_limiter
Nope you can change it all with dash in. Ive done it to many times. For dash being pulled you have to remove windshield for 2 bolts I believe.
Huh? You must be talking about the dash frame . The cluster itself is about 15 min job
Finished the job a week or so ago. Dropped the steering column for access, The owner picked up a factory replacement limiter, and everything is back to normal. I told the owner, about the RTE unit, and he has one on order.
