1970 SuperBee A/C Wiring Diagrams?
tskw914
11:19 AM
NY
Hi,
I have a 1970 Superbee w/ the 383, has factory A/C, its all there and hooked up but it does not seem to come on. I see one wire coming off the back of the compressor that looks like its tied into another wire then disappears into the wire look. I was wondering if someone had a wiring diagram for the engine compartment or the Air Conditioning system?
thanks
I see the post is old, but i'll post a reply
I haven't worked on anything that old, but on newer AC systems there are temp probes or pressure cutoffs somewhere on the lines. Do you see anything like a probe wrapped to the line or a black box near a line?
Also some systems will not engage if there is no or low refrigerant in the system
dont see anything taped up, it may be low I have not had time to deal with it yet.
Take a look on the expansion block at the firewall connection or on the drier canister itself.
