roguerunner
- 11:21 PM
- Oct 25, 2010
- Sth Coast, NSW, Australia
Started life as a Sebring with 318/904 & 8 1/4 rear. Not long after I bought it in October 1982 I transfered a 340/727 from my Aussie Charger into it. Fitted an 8 3/4 from a Dodge Pheonix (RHD Plymouth Fury). After patching up things over a few years I decided to pull it off the road in 1988 for a restoration. Now it is nearly finished after many years sitting in the shed.
First job was to clean the under carriage and paint it.
When I started on the rebuild there was no Internet and Mopar parts were hard to buy in Australia so I decided to go for a XJ6 Jag front end to fix the poor brakes & steering problems the RHD conversion had caused.
To fit the Jag crossmember the 440 needed a modifed Truck sump but otherwise it was a easy fit.
The firewall was redone using an Aussie Valiant for the factory look to the RHD conversion. Before/During/After
The instrument panel is a highly modified Valiant unit enlarged to fit a B body Rallye Panel.
The 440 is a 72 build & has 10:1 Speed Pro forged pistons with Eddy heads & a Mopar 509 Purple Shaft. Rocker covers are original Cal Custom ones. Dual Quad is an Eddy unit & I am running Impco 425 Propane carbs.
Motor is only in for a test fit & will be pulled out soon to be painted a Silver Metallic color along with trans & diff.
I have chosen to run Rallye rims in 15x8 & 15x10 chromed version.
more to come cheers Colin
