1973 Dodge Charge Speedometer cable help
Texas charger 73
9:12 PM
Texas
i think my speedometer cable finally broke... i need a replacement and they offer like 3 different length.. i haven't pulled cable yet and would like to go ahead and order a new one...
car is a small block 904 with
standard dash if that matters... i was told that the cable for the Rallye dash is different, but that could have been bad info too..
does anyone know the correct length or a part number?
I know this is not a direct answer to your question, but I recommend you remove it first, then take it to a local speedometer shop if you are lucky enough to have one nearby. When I had my cluster restored, the shop I went to informed me that they make custom speedo cables. The custom ones were heavy duty (coiled steel outer tube covered in heavy plastic, I think), and the authorized repo I purchased was lightweight plastic junk in comparison, and if I remember right the cost was only $20 over the repop.
