- 8:39 PM
- Oct 16, 2014
- Salisbury, Vermont
This is a known good motor that I have seen running. it was removed from a motor home with 70,000+ miles on it. I was a good running motor. It has been garaged since then and oiled up periodically to combat rusting.
It's a complete block and heads from the crank up. it comes with: iron stock 440 intake, stock water pump, valley cover clamps, exhaust manifolds, timing chain and cover is on the motor, 600CFM carb, distributor shaft and gear, oil pan without pick up tube.
This is a -8 block and would be suitable for mild over bore and street duty. Not so much for racing. I was going to put it in the Express but got a complete running engine.
$ 400.00 plus shipping.
