1975 440 hp rating?
blubyu
New Member
6:22 AM
Ontario,Canada
Hi I,m new to the site,also new to BB Mopar.I got offered a 1975 440/727 out of a motor home today.Engine/tranny only have 37,000 miles.What,s the hp rating?compression?Would adding some good heads to the stock bottomend be worth it?Also whats a good aftermarket intake for this engine?Thanks in advance for any help.
Only goes to 74 and probably pass cars. but might be close.
I think they changed the comp ratio by using different pistons.
I'm sure someone will correct me if that's not correct.
Pistons shouldn't be too hard to find if you're into rebuilding.
My Dak R/T has 250 net HP and screams (for a CC truck).
Won't beat a mustang, but will biol the tires all the way off if you don't lift your foot.
Motor home engines are weird. Cooling system is strange. Heads are poor flowing and also have a ver low compression. Best part is the block and crank, throw away the rest and start over
Apparently my experience with MH engines differs from the above...
Truck engines are a vastly different breed and often the MH are lumped together with the trucks but are in fact closer related to the pass car.
The MH cylinder heads are not the same as the truck 413/440, but may have exhaust rotators (not a bad thing) and they do have better coolant passage design around the spark plug.
The cast crank in a 440 or 440 is good for about 500hp...the only issue with a cast crank is the balance.
As far as the horsepower and torque numbers go, in 1972 changes were made to the system of measuring power of vehicle engines from gross (engine only, without air cleaner, exhaust system, alternator, or other power-consuming components) to net (with alternator, air cleaner, mufflers, and other vehicle equipment installed). The new rating system produced lower, more realistic numbers for any given engine. At the same time, emissions regulations were demanding cleaner exhaust. Engines including the 440 were made with reduced compression, modified cam timing, and other tuning measures to comply with the newly-tightened emissions regulations. The 1972 440 produced 335 bhp (250 kW) (gross) at 4400 rpm; the new net rating, for the same engine, was 225 hp (168 kW)—which very closely coincided with period German DIN ratings and TÜV measurements.
73rr is right. MH's equipped with the 413 got the weird looking water pump housing but it was the industrial/truck engine. Water ports went to the heads and block and the pump insert was mounted high in relation to the passenger car engines. 440's in MH's did not get that setup. As for compression, the pistons are in the hole at least .100" and even tho a closed chamber head will raise compression some, it's not worth the effort. The difference between open and closed chamber head run about 10cc.
Forgot the link
http://www.mymopar.com/enginespecs.htm
In 71, compression was 9.2 or 8.7, in 72 it dropped to 8.2:1.
My 70 Super Bee had a 74 400 from a van for a little while, and it still screamed.
