SOLD 1975 Roadrunner Fury with 1972 440 4 speed for parts
12:57 PM
NJ
I'm afraid I don't have a title but I have a 75 Roadrunner / Fury for sale with a 440 and 4 speed from a 72 RR. Located in Hammonton, NJ $2800 obo
We're going to need alot more pictures then that! And info!!!
The motor is not currently running but turns freely and did run within the last year or so I was told. The guy I bought it from had full intentions of putting the whole drivetrain in his charger project. The trans shifts freely and the rear is 8 3/4 I was told its a 3.55 rear and that the engine has a mild cam but the owner lost the title and the cam spec sheet.
Your browser must not support the embedded image viewer. Try typing this out:
imgurDOTcom/a/dJ2R7
FYI, Pictures are showing for me.
I'm afraid I don't have a title.............
Not familiar with NJ policy. What's the story on the title, can you get one? What does it take?
Do you happen to know if the 440 is a big beam rod engine?
NJ is a pain. The last owner lost the title and its so old it's not in their digital system to get a duplicate. I've gotten a title before using a friend in PA and the VT registration method but it's time consuming. The block is stamped H440 which is a 72. If you know an easy way to ID a big beam I can certainly try and figure it out for you.
..........If you know an easy way to ID a big beam I can certainly try and figure it out for you.
Possible the previous owner knows or any hear-say? Crank balancer may be a clue?
I don't know if the original 4 speed engines were big beam, but my auto was.
this is actually a great! price for a drivetrain,esp a 4 speed setup,and hey it comes with a car.
wondering why you dont keep it for your charger build?
what is the trans,a 833 or an overdrive?
This should be a coarse-pitch 18 spline a833 with a 2.44 1st gear no OD. I'd love to keep it but I need to recoup some of my initial investment into the Charger. I already run a small block in my 'Cuda. Plus the charger still has its original drivetrain.
wish you were closer
it isn't bad if you can drive for more than an hour at a time :D
I don't see any pictures but one!
NJ motor vehicle is hell if you don't have title & proper docs.
Is the motor stamped HP and what is the first 5 of the car vin number?
