318 LA kick down spring
mrsnicks
8:12 AM
cameron, nc
Trying to describe it so you know what I'm talking about. Getting everything bolted up on my rebuilt 318 LA engine and the kickdown lever was missing when I bought the 71 Charger. I have sourced a correct kickdown linkage, but need a source for the spring for it.
Any part #'s, links, names and/or vendors would be appreciated.
Nobody has bought/sourced/replaced the return spring for the transmission kickdown??
I just use a spare throttle-return spring. I had to use a double on the throttle return though to be 100% sure of overcoming the TV spring, but I got used to the stiff pedal after awhile. If you're looking for an exact factory-match restoration part, then I have no clue. Good Luck with it!
