318 to 440
xRickyBobbyx
7:04 PM
Chicago
Hey guys. It's been a few years since I've been on. Life has a way of telling you NO YOU CAN'T DO THIS RIGHT NOW. So now I'm in a space to where I can finally start to make some progress. Long story short, I bought a '69 Coronet 4-door with a 318. It's literally been sitting for 3 years in my garage. Still started until the battery died on me. Haven't jumped or replaced it because....why. Anywho, I was looking at either building the 318 up to about 350hp, or swapping in a 5.7/6.1. However, I recently got into conversation with a guy for a '66 Coronet that has a 440 for what seems like a good deal. It's a crashed car (side damage) 7 years ago. He said he started it up 3 years ago and going to see if he can start it now. Initially I was just looking to get the engine and trans. But If I get the whole car, I'm guessing the rear end would be useful also since the one in mine would be a bit anemic. Not sure what else I might be able to use from it.
So my questions are:
What, if anything, should I be looking out for to do the swap? Is it a simple plug and play or are there going to be modifications?
Do I have to make changes to the K-member, motor mounts, etc?
Perhaps you are unaware but a 66 would not have had a 440 originally.
It could have had a 383 (or a 426).
But you would need everything, radiator, engine, transmission, engine harness, exhuast and possibly a driveshaft as well.
Something as simple as the transmission linkage could be an issue if it's a floor shift vs a column shift.
But if it's all there it's possible, many have done it.
Thanks for the heads up. Is there a way I can find out which it really has? Not to sound like a jerk, but if by chance it's a 426, for the price I'm getting it for, I kinda don't want to let him know. LOL!! He sent me a picture of the engine. But I'm not enough of a gearhead to be able to tell the difference just by looking at it.
Well first of all, show us the picture. :) Is the distributor in the front or the back of the engine?
I can't say from that picture, might be a B and engine not an RB. (383 or 361)
Looks like a 5/8" return line on the power steering pump so it's possibly the original power steering pump.
Ask if he can send you a photo of the 440 engine boss stamping. It's on top of the engine right in front of the intake.
Either way I'd be looking for a new engine harness.
I don't think you want to re-use that one.
Yeah. I had intended on replacing all of the wiring front to back. This is a car I plan on passing down to my son.
Usually just everything in the engine compartment gets hot/brittle and suffers from corrosion.
I've never had any problems from the interior and rearward.
