318 to 440
xRickyBobbyx
5:20 PM
Chicago
Hey guys. It's been a few years since I've been on. Life has a way of telling you NO YOU CAN'T DO THIS RIGHT NOW. So now I'm in a space to where I can finally start to make some progress. Long story short, I bought a '69 Coronet 4-door with a 318. It's literally been sitting for 3 years in my garage. Still started until the battery died on me. Haven't jumped or replaced it because....why. Anywho, I was looking at either building the 318 up to about 350hp, or swapping in a 5.7/6.1. However, I recently got into conversation with a guy for a '66 Coronet that has a 440 for what seems like a good deal. It's a crashed car (side damage) 7 years ago. He said he started it up 3 years ago and going to see if he can start it now. Initially I was just looking to get the engine and trans. But If I get the whole car, I'm guessing the rear end would be useful also since the one in mine would be a bit anemic. Not sure what else I might be able to use from it.
So my questions are:
What, if anything, should I be looking out for to do the swap? Is it a simple plug and play or are there going to be modifications?
Do I have to make changes to the K-member, motor mounts, etc?
Perhaps you are unaware but a 66 would not have had a 440 originally.
It could have had a 383 (or a 426).
But you would need everything, radiator, engine, transmission, engine harness, exhuast and possibly a driveshaft as well.
Something as simple as the transmission linkage could be an issue if it's a floor shift vs a column shift.
But if it's all there it's possible, many have done it.
Thanks for the heads up. Is there a way I can find out which it really has? Not to sound like a jerk, but if by chance it's a 426, for the price I'm getting it for, I kinda don't want to let him know. LOL!! He sent me a picture of the engine. But I'm not enough of a gearhead to be able to tell the difference just by looking at it.
Well first of all, show us the picture. :) Is the distributor in the front or the back of the engine?
I can't say from that picture, might be a B and engine not an RB. (383 or 361)
Looks like a 5/8" return line on the power steering pump so it's possibly the original power steering pump.
Ask if he can send you a photo of the 440 engine boss stamping. It's on top of the engine right in front of the intake.
Either way I'd be looking for a new engine harness.
I don't think you want to re-use that one.
Yeah. I had intended on replacing all of the wiring front to back. This is a car I plan on passing down to my son.
Usually just everything in the engine compartment gets hot/brittle and suffers from corrosion.
I've never had any problems from the interior and rearward.
Motor mounts are the same on 383/413/426/440 engines
in that year B body. Only would take a minor mod on wiring
harness for front distributor and coil. In my opinion easy deal.
Getting the whole car would simplify and drive train issues and wiring
etc.
Check to see what rear end is under your 69. Probably an 8.75 but could be an 8.25. The 66 should have an 8.75 which is a little narrower than the 67-70 rear. If yours already has an 8.75 than your good to go.
As Sam stated before, look for the pad on the block.
Ok... so the car originally came with a 361. The 440 was swapped in. It has an 8.75 rear end with 3.23 gears. So that's all perfect. I can swap that over. It's likely my 318 has different gears.
That's sounding good. If you get the whole car it is easier. You know the rad fits, you know the transmission kickdown linkage is complete etc. I forget if the wheelbases are the same but if it is the driveshaft will swap over too, you'll need a 727 driveshaft. The whole car is the way to go.
If the other car originally had a 361 it may have heavier torsion bars than your 318 car also.
Wheelbases are the same. I'd just about want to drop the whole K-member and swap the entire drivetrain.
Didn't think about the torsion bars. My idea was to use everything I can. So it may have crossed my mind during the strip down.
My 69 has a 727 auto that's original to the car. When I initially drove it around, the shifts were really soft and slow. Could just be the way it is. I have ZERO experience driving a 727 3 speed. The donor car has one also. I'll be using that one since it's already connected to the engine. And the previous owner likely did some work to it. It was crashed only 7 years ago.
I'd keep the 69 K-frame. Has the better idler arm setup.
Also chances are the 318 came with 3.23 gears unless it has an A code option.
I was assuming mine has the 2.94 gears. But it's possible I already have 3.23. I'm going to talk more with the seller when I pick it up about what was done to it.
