Ray70Chrg
new lunati 703 cam, lifters, springs, timing gears & chains. Degreed cam and properly break-in process with lighter springs, then put in proper strength springs. I have no concerns about the new parts and their operation. Started engine, set initial timing to 15*btdc, connected distributor vacuum hose to manifold and that brought advance to18*,rpm's are 950/1000. Adjusted both carb screws for 20 inch vacuum. Idles nicely. Rev it up and release, idle returns to same values. Cam that came out of car is unknown. No manufacture id. Certainly no purple marking. When I put in gear rpm's reduce 300-400 revs and idle is unsteady and ready to stall. Put back in park or neutral and idle returns to normal. Carb is a Carter 625 Performance Series and I had no problem like this before. Is it possible carb is now a mismatch for this higher performance cam? Intake manifold, 906 Heads, & hp exhaust manifold are all stock. Trans is 727b. Any ideas appreciated.
