69Runner
This will be a first for me, a full conversion. I rebuild the 4-speed in my Roadrunner a few years ago, so the process of removal and re-assembly is familiar. This is also a father-son(s) project so we're just having fun.
One obvious thing that needs to be addressed is welding in the ball stud frame bracket for the z-bar. That is probably my biggest concern. Not sure if it can be done with the brake booster and steering column in place. But I'm prepared to remove the column.
From several sources, a 1967 steering column differs in some way from the 68/9. And according to Brewer's their floor-shift conversion collar will not work with the 67. Reproductions of the 68/9 collar run around $130, and used ones pop up sometimes for 100.
Being the impatient but cheap type (bad combination) I went ahead and acquired a cheap 68/9 auto column and set about to convert the collar, instead of forking out the 100+. The other benefit is the steering column will be fully re-furbished ahead of time.
Turns out the collar diameter is the same as a large tomato can. So after grinding off the PRND window frame I fit in a piece from the can, screwed it in place, gobbed on some Quiksteel, sanded then primed. Presto a floor shift collar conversion for $5.
