4 Speed Conversion
So that would be another alternative to buying a flywheel designed for external balance? Did you pull the motor when you did your conversion? I feel like it might be easier with the engine out to weld on the ball stud bracket and align the bell housing. Especially if I have to put in offset dowels.
I did not take out the engine......I made a bolt in ball stud bracket like the factory used on the frame side and just screwed in the ball stud on the engine side.....I have a hoist in my garage so that makes things a bit easier...
