400 Stroker Rebuild Sounds Like a Bucket of Bolts
The excessive side clearance is rather clear, the question on the table was it livable?
would you want it in your street car ? you think it would be noisy plus it would side load the pistons against the cylinder walls. effect ring seal maybe.
I don’t agree with “the damage is done. It can’t hurt it anymore” “start the engine”. And they kept accelerating the engine.
If I heard that I would shut it down right away
gotta include a little drama for youtube
No, not for a second, but Nick seemed to imply he has seen it before and the downsides were not observed nor obvious, and why I thought the question was worth asking.
I "thought" side clearance played a major role in oil flow/pressure operating aspects.
it seems like it does not affect oil pressure unless it exposes the oil holes in the crank journals. must be a reason the factory wanted 9 thousand-17 thousand clearances and not 250 thousand like at Nicks.
Did nick happen to say what the oil pressure actually was? I’d be pulling the front cover and degreeing cam and checking for missing galley plugs.
