408 Stroker build...need help
'72 Charger
9:12 AM
San Antonio, TX
I'd like to add that this is my first attempt at building an engine. The power plant in a crate 360 Magnum with and an 8 3/4 Sure Grip rear with 3.23 gears. I recently purchased a Holley HP 750cfm, Edelbrock Air Gap manifold, Hooker 1 3/4 LT, Crane ignition kit (distributor, coil, rev-lim, 8.8 wires etc.), Meziere water-pump, triple pass radiator, trans and oil coolers. I'd also like your suggestion on rockers, rods, rings, retainers, springs, etc all things associated to the cam installation.
Any help you can offer I would treat as gold.
I have taken the liberty of adding a few items I've researched and think would fit my application. Please advise freely on your suggestions, like I said I'm new to Mopar and a carburetor engine build. Here are my selections:
Needed advise:
-Porting and Polishing Magnum heads advice
-Transmission improvement kit (auto)
-Torque Converter-lower RPM stall
-Cam (I want the car to sound like a true muscle car, torque beast. This project will never see track or drag time; strictly street driven. Your suggestions are highly appreciated.)
-Stroker components
-Rods:
*Racing Series 4340 Steel H-Beam Rods, Chrysler SB, 6.123",Racing Series 4340 Steel H-Beam Rods, Each rod starts as a high quality 4340 forging
*H-Beam Connecting Rod, 4340 forged material, H-Beam design for proven strength, Standard ARP 8740 Cap Screws, SAE 4340 STEEL CONNECTING ROD W/ ARP 8740 BOLT, LG3-6123H, CHRYSLER 6.123" H-BEAM ROD FOR 318, 0.984
*Scat, 4340 Forged I-Beam Rods, Chry SB, 6.123", Bushed
*Eagle H-beam connecting rods are forged from SAE 4340 steel,Length: 6.123. Weight: 695g, Design: H-Beam, Journal Size: 2.125, Pin Size: 0.984, HP Rating: 750
-Crankshaft:
*Eagle 103604000 SBM 360 Cast Steel Crank- 4.000in Stroke
*Scat 9-360-4000-6123 SB Chrysler 360 Cast Stroker Lightweight Crankshaft,
4.00" Stroke, 6.123" Rod Length, 2.125" Rod Pin
-Pistons:
*Speed-Pro Forged Pistons ZL2386F30, Pistons, Forged, Flat, 4.030 in. Bore, 5/64 in., 5/64 in., 3/16 in. Ring Grooves, Mopar, Set of 8
*Probe, Model: 13744-030, Chrysler / Mopar, Small Block V8, 408, 1.46, Reverse Dome, -17.5, 2618-t61 Forged Aluminum
-Torque Converter:
B&M 10416 - B&M Tork Master Torque Converters, Torque Converter, Tork Master, 2,000 rpm Stall, Mopar, Torqueflite 727
MOPAR - 1996-up 727 Performance / Econo Convertor Item# MOPP5007296-CL
-Cam:
Lunati's Voodoo Hyd Roller Cam - Chrysler 273-360 276/284, Part Number: 20200212
Advertised Duration (Int/Exh): 276/284
Duration @ .050 (Int/Exh): 210/218
Gross Valve Lift (Int/Exh): .492/.492
LSA/ICL: 112/106
Valve Lash (Int/Exh): Hyd/Hyd
RPM Range: 1200-5200
Includes: Cam Only
Xtreme Energyô, XR268HR-10, Street Machines, Stock Converter in 340 & 360, Cam Style Hydraulic roller
Basic Operating RPM Range 1,400-5,500
Intake Duration at 050 inch Lift 218
Exhaust Duration at 050 inch Lift 224
Duration at 050 inch Lift 218 int./224 exh.
Advertised Intake Duration 268
Advertised Exhaust Duration 276
Advertised Duration 268 int./276 exh.
Intake Valve Lift with Factory Rocker Arm Ratio 0.535 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.531 in.
Valve Lift with Factory Rocker Arm Ratio 0.535 int./0.531 exh. lift
Lobe Separation (degrees) 110
Intake Valve Lash 0.000 in.
Exhaust Valve Lash 0.000 in.
Computer-Controlled Compatible No
Grind Number XR268HR-10
-Roller Rockers:
Proform Parts Extruded Aluminum Roller-Rocker Arm 1.5 Ratio - 66869
-Water Neck:
Meziere Water Neck WN0030U, Water Neck, Billet Aluminum, Polished, Straight Up, Mopar, Small Block
-Fan:
Summit RacingÆ High Output Electric Fans SUM-G4851, Electric Fans, High Output, 3,100 CFM, Dual, 12 in. Diameter, 26 in. x 15 in. x 3.25 in., 26.6 Amps
-Pulleys:
March Performance, Pulley Kit
March Performance, 318,340,360 c.i. Alternator Brackets, #40051
March Performance, Small & Big Block Power Steering Brackets, 318-340-360-383-426-440c.i., #40061
-Ring Set Total Seal #9024030NF (1/16-1/16-3/16"
-Rod Bearings #4101HN Clevite "H" series
-Main Bearings #4017 Clevite "H" Series (Wide Flange 74-03 blocks)
Looking to start purchasiung parts next week guys. Any help in this area would be a huge Plus!!!
THank you
You've listed a big ehough bank roll of parts that you could simply buy a completed car.
