I had started another thread on weak performance on this 426 Hemi. Started the tear down and have several questions .
So I want to detail and re paint the engine compartment regardless, so engine is out. This engine has not run in several weeks. There was all this liquid on every closed intake valve, to thin to be straight up oil, if it was gasoline from the last time it was shut of warm it would have evaporated right?
This is the first Hemi I have ever disassembled. Are the pistons supposed to top out below the blocks deck by a good 3/8 of an inch. As seen by the carbon line in the cylinder the top ring line is about 9/16 + from the deck, is this normal? Pistons appear to have Mopar part numbers. Bank one ends in 569 bank 2 ends in 568.
Also are these Milodon tube seals seated? All the tubes had marks as if these were misaligned.
The engine had great oil pressure but the cam bearing don’t look so good. Some seem like they were not centered in the bore, misalignment of oil hole. It is hard to capture in a photo but very odd wear pattern .
Would really appreciate some input from members familiar with these.
Thanks Dan
Thanks Dan
