am3rican
bought my fixed fan blade at summit... Part No. FLX- 5719 it´s a huge 19 " fan.. with 6 blades
Greetings Juergen
Thanks Juergen. This is what I was looking for.
Greetings Juergen
have the same "problem" ... my 440 runs great on the "Autobahn" ( highway... ) about 185 °F with a 180 thermostat... FlowcoolerPump, 180 highflow thermostat... New aluminum radiator... Fan shroud ... 7 blade Flex a lite... timing @ idle 10 deg btdc all in @ 38 deg ..
normaly everything should be o.k......... until I slow down...like in city traffic "She " goes up to 210 °F
Tomorrow I will recive a 6 Blade 19 inch race fan with steel blades.... hope this one will cure the problem...
Greetings Juergen
Maybe because its so late. But I am confused.The FAN I use now...is a FIXED one.... this type of fan will not work with a fan clutch. The only FAnclucht that works is a FLX-5555 because the total hight is only 3.03 " the clearace from the WP to the radiator is aprox. 3.6 " so the 2765 Hayden should be to " large".. 3.30" afaik...
Greetings Juergen
Update on this: the timing is off. The engine has been idling high. I strongly suspect pre-detonation. It has been ticking when hot when off the throttle. Only hear it when engine is hot and when I'm decelerating. Have not noticed while throttle is applied. Will be switching to 20w-50 because I'm thinking it may be be lifter noise too. Going to take it to Herbs parts for tuning.
Carbs were rebuilt by PO few years ago.
The 'timing' you're showing (post 34) is actually the specifications for your camshaft. These show at what degree (out of 360*, and in relationship to top dead center (TDC)) your cam opens and closes the valves, as well as how much they open. They are not something that you normally 'adjust' after the engine is built.
Ignition timing is another subject, and is adjusted as part of a tune-up, typically expressed as 'so many degrees before top dead center'. There is initial timing and total timing as well as timing added by a vacuum advance unit. Neat stuff to learn if you're interested in getting the most from your ride.
