440 - coolant running out of exhaust bolts
josephqatarcarguy
5:43 PM
Qatar
hey lads, while pulling the headers to swap out my started - removed the header bolt and coolant came rushing off -is this normal?
no leaks - engine oil is the right color( not mixing ) - no temperature issue etc i have read this is normal?
Yep. Very common. The bolts holes for the exhaust go into the coolant passages.
Drain the coolant enough so it's not leaking. Get the coolant cleaned up in the threads. When reinstalling header bolts, use Teflon tape or something to make them water tight.
Joseph, all of the exhaust bolts / studs will need sealed.
Like posted above a good high temp thread sealant is the way to go.
I used permatex ptfe, on all studs just in case, no leaks.
Depending on your header configuration, you can use studs on all holes except #1 inner
