Ironbuilt
- 11:53 PM
- Jul 1, 2017
- North Carolina
I would start with the assumption that the car has been sitting for a LONG time. Start by draining ALL of the old gas. Drain into a clean bucket and look for sediment and/or debris. If the gas is relatively clear, change the fuel filter and add clean, fresh gas. Next, get a can of quality carb cleaner and clean both carbs thoroughly. Remove air/fuel mixture screws and clean the screws and the holes. Clean all linkage and check for free operation. Install mixture screws until the seat, don't overtighten. Next, back them out 1 1/2 turns each to start. Crank engine to start and check idle rpm. Adjust idle screw to roughly 900 RPM idle in park. If the car idles decent and the throttle response is good, problem possibly solved. If idle is still bad, or won't idle at all, check timing, in Park at 1000 RPM. Disconnect the vacuum advance line and plug, if so equipped. Set initial timing somewhere in the ballpark of 14 degrees to start. Check idle again. If still not good, check plugs, wires, cap, rotor, etc. If still an issue, check coil. I could go on for pages, but now at least you have a map of sorts of where to start.I've only had the car a few weeks and I had it shipped to me from Wisconsin. Again I'm not sure how long the car had been sitting but it's in really good shape body wise, no real rust or Holes, when it got dropped off it did need a jump start to get it going and I put it on a charger and the battery holds the charge because it'll turn over and the interior lights come on when I open the door and put the key in the ignition, it just won't stay running without it being continuously fed gas. As soon as I take my foot off the gas it starts sputtering and then dies.
Post pictures and good luck.
