RestifiedBee
I have a '69 Super Bee. When I got it (over 20 yrs ago) it had an 1964 dated 426 wedge (steel crank) with the original 727 auto. It ran and drove fine. The block froze and cracked. I found a running 440 (cast crank) out of '72 Imperial, swapped it out. When changing the parts over, my crank pulley wouldn't bolt up to the balancer, so I swapped it out for one from the 426. I didn't change the flex plate. Now I have a vibration/hum above 30 mph. I've done some research, correct me if I'm wrong, I need to change the balancer, for one externally balanced and the flex plate also for an externally balanced one that will let me keep the same torque convertor like a B&M 10237
