So is this advanced 20 degrees? So should I be close to where the rotor points to the #1 plug wire? Thanks in advance.
Depends on how much cylinder pressure the engine has. If it's 8.5-1, cylinder pressure (with a stock cam) will most likely be low and will like more initial and total. At least that's the way every low compression engine I've worked with was. My recommendation is to give it what it likes.....Yes... you'll need to confirm with a light once running.... BTW, 20 initial advance is kinda a lot on most engines at start, which is what you are doing right now.... I'd dial it back to 5 to start most likely.
