Mike Mc
Hello Gentleman, new to the board and this is my first post. This post is not reguarding a B model but I can't figure out whats going on so I'm hoping you guys can set me strait.
I traded a 1941 Caterpillar D2 for this 1968 D100 Sweptline with a '76 440 pick up engine with a cast crank.
Running about 1,500-2,000 rpm it has a vibration in the engine that smooths as it revs up. The vibration is real bad when de-accelarating, it shakes the cab and gives a funny feeling like driving with the back windows down in a car. I believe the vibration is getting worse.
The truck runs great! Lots of power and can't feel the vibration when under power only with light throttle and especially when slowing down.
It's now on jack stands and this magnifies the vibration even more with the tires not being on the ground.
Here is what I've done so far,
1. I gave the truck a complete tune up and it's hitting on all 8.
2. Did a compression check and all the cylinders were between 140-150 psi.
3. Vibrates with the clutch in or out.
4. The harmonic dampner slid back and was rubbing against the timing cover. So I found a new/used one on ebay that said "use on 440 with cast crank only" just like the one that came off. Thinking this new/used balancer/dampner would solve the problem but the vibration is the same.
5. Installed a new double roller timing chain and sprockets.
6. I removed the clutch cover and no weights or parts fell out. All the pressure plate bolts are tight and in place.
I'm stumped and don't know whats going on. Please advise!
http://www.youtube.com/watch?v=jXRmZazaISE&list=UUaD3qYflKm7V1L4gjmzmu6w&index=5&feature=plcp
http://www.youtube.com/watch?v=NL6PP7pyekY&feature=relmfu
Thanks, Mike
Thanks, Mike
