- 10:57 PM
- Oct 18, 2008
- Kindersley,Saskatchewan, Canada
I wish u luck. With zero deck flat tops and a 75cc head and a .040 gasket u will be around 13.5 compression. U will have to change the pistons. That cam will only make matters worse. Thick head gaskets will only make matters worse as u will need mega thick intake gaskets and then there is the problem of sealing the end rails. Kim
