DartProject62
Good Afternoon Everyone!
This forum is such an incredible community! Thank you all for all the help so far, you have made my project so much more manageable!
I am seeking help today with my rear end (of my car). I am very new to restoring cars and dont want to make a mistake that I cant undo. I have begun by removing the rear end of my 1962 Dodge Dart. I had some difficulties removing the rear end, to include snapped bolts (shock absorbers, hanger bolts and a few others). I was not able to removed the single bolt on the leaf spring and had to remove the hanger instead. I also had a tough time with the shackles on the back. After getting the rear end off, I wanted to pick your brains and make sure that my proposed actions are the correct actions. Would you all be willing to
provide some feedback and let me know if I am gonna do something stupid or if there is a better way of going about it? I have seven areas that I would like help with, Hangers,Leaf Spring Bolts,Leaf Spring Repair, Leaf Spring Mounting Plate Ubolts, Leaf Spring Mounting Plate Shock Absorber, Cleaning Diff, Diff Seals (sorry if my terminology is incorrect, very new at this all)
Car: 1962 Dodge Dart 4dr
Rear End: I believe it is a 8 3/4 rear end, 741 #2070741
#1: Hangers - I had to remove the hangers because the bolt on the leaf spring was stuck and I was unable to get it off. To clean and replace the hangers is there
anything I need to do beyond hitting it with a wire brush to bare steel and repainting? Is there anything to look out for before placing back on the vehicle?
Currently my plan is to just clean, paint and place back on the vehicle. Right now I dont think there is anything need to buy any replacement parts. Thanks much!
#2: Leaf Spring Bolts - I was unable to remove the leaf spring bolts. Does anyone have any suggestions for removing these bolts? Would it be OK to get
a cutting wheel and replace the bolts all together? I am afraid to cut the bolts and damage the leaf springs. (If the leaf springs have to be replaced this is a non issue)
I can get the bolts for about $20 online. Should I cut the bolts off or try to find a different way of removing them?
#3: Leaf Spring Repair/Repair - The leaf springs look like they have been on the car since the factory. I am not sure if there is a way to keep using them or if
they must be replaced. If they do have to be replaced, is there things to avoid? Are there things to keep in mind when finding replacements?
#4: Leaf Spring Mounting Plate Ubolts - The UBolts on the leaf spring mounting plate are not budging. I think I broke a ratchet trying to get one off. I
would like to go get a cutting wheel and take off the UBolts. I am not sure if they can be replaced easily. Could I replace these bolts with Ubolts from the hardware stor?
Or do these need to be specialized bolts specifically for the mount?
#5: Leaf Spring Mounting Plate Shock Absorber Post - I snapped this bolt off when trying to remove the shock absorbers. I found a stud replacement (thanks to you guys!!! BIG HELP!!!)
that I will be ordering and replacing. My question is on the shock absorbers, is there a specific one to replace them with? Is there a reason to upgrade, will it make a difference.
#6: Cleaning - The rear end is gosh awful dirty. There is oil leakage and just oil dirt and grime from the last 60 years on it. My plan is just to hit it with a wire
brush and take it down to bare metal and repaint. Is this wrong? Is there a better way to clean the dif? Should I consider some type of acid bath? Also,
would it be worth my time (and money) to take the diff to a shop to have it checked out?
#7: Seal - What seals should I replace when restoring the rear end? I know I will need one on the pumpkin, but shouldnt there be some on the wheels as well?
Thank you all so much for taking the time to read my post. I am very new at this and am enjoying this immensly! Your help has really made it much easier! If anyone
has any helpful tips or suggestions they would be much appriciated!
