64 Polara Turn Signal Switch
avidflyr
7:29 PM
west Coast Florida
The Plastic Turn Signal Switch (new & under horn ring cover) Has broken (& replaced ) 2 times. Seems to be fairly brittle. Has anyone found a reliable replacement ?
Use Nos only and never have to tear the column apart again. Used ones are brittle and after market ones are junk. I have one left that is heading to Carlisle $200 shipped and it will last your life time...
Are you referring to the switch or the cancelling cam?
Mike
The Turn Signal Switch base is made in Argentina, the cams are not labeled so when the last one brakes I'll go with the Mopar...THANKS to ALL.
