Vrenlos
Turns out it was the embarrassing (but best case) scenario - the gallon of gas I put in wasn't enough to get everything primed/running. 5gal did it!
Your gauges look nice, from the color of the pointers looks like a JC Auto rebuild. As for the points style limiter inside your fuel gauge, over time the points start sticking and instead of the 5V ref voltage you need for fuel, oil press, and temp (thermal gauges), you get 7, 8, 9 etc. Starts to burn the insulated nichrome wire off of the bi-metal strip inside your thermal gauges. First they lose calibration, bad enough they fail entirely. About 80 percent of the 66/67 Charger gauge restos I do have burned up thermals. To install a RTE IVR 3 limiter on the back of the cluster, you'll need to disable the points inside your fuel gauge. Pretty positive JC Auto already did that. They have probably installed an external limiter as well, but they use an old style points type. That needs to go....replace it with the IVR-3...
As for your tach, can be one of three things:
Bad external tach sending board (RTE sells the correct tach board, tho it needs to be calibrated to your tach)
Tach binding on the bottom pivot from dirt after 50 plus years
One or more electrical components on the tach itself has failed
To test the tach (if its not bound up), can use a 1.5V D Cell battery, connect the positive side to the copper post (one with the tab), negative to the silver post. Should read 2000 RPM plus minus 200 or so...
My website has more info. Feel free to contact me if you have questions...always glad to help...
Mark
