66' Satellite Rear Suspension Rebuild
robinsonwr
9:23 AM
Carriere, ms
Well guys after much debate and much advise I decided to stay with the stock appearing theme. The car will driven a lot once complete so I decided on XHD springs, ADDCO 675 rear sway bar, New adjustable front hangers (AR095), hanger reinforcement plates (AR107), and Rancho RS99116 9-way adjustable shocks. I will probably add an adjustable pinion snubber also. I wanted a suspension that would plant some power without giving up on ride quality. Yes a 440/512 mill will be between the frame rails making around 600hp and 650tq. Does this combination have validity on what I want?
View attachment 181320View attachment 181321View attachment 181322View attachment 181323View attachment 181324View attachment 181325View attachment 181326
Should work fine for what you say you will be doing. Might not hook all that torque as well as a set of Cal Traks but will look more original.
Wayne
Wayne
I appreciate your comment. I know the Cal Traks are the way to go if I were leaning more toward street/strip. I will be extremely happy to slap on the 28 X 9 X 14 MT's and click off a low 12 pass. I do not think that will be totally out of the question with the set up chosen. Actually I think it could possibly have some 11's if she is tuned correctly. What do you think?
I think I will start with the shocks set for 6-7 on driver's side and 3-4 on passenger side.
