67 belvedere hood trim fits 66 coronet hood trim?
dnlsctt
6:23 AM
Austin, Texas
Im looking to purchase some last bits of trim for my 66 coronet. I found a guy who has a 67 belvedere hood trim. Would it fit my 66 coronet?
Thanks for the help!
I dont think there the same.. the front lip moulding will have a black color strip in the middle on the Plymouth.. The coronet wont.. I could be wrong..
Not the same. It may fit, but won't have the same contours of your grill surrounds.
Nope
...and for what ever reason clean 66 hood trim is very hard to find.
In that past I typically find 3-4 67 hood trims for every 66.
The 67 will work but it has a pointy profile, not square, like 66
It won’t go on, it mounts different.
Coronet mounts with studs and nuts running front to back.
Belvedere mounts with screws from the bottom up.
If you compare 1966 to 1967, and Belvedere to Coronet it is all different trim.
1967 Belvedere can have either black or white paint in the recessed groove, 1967 GTX and
Satellite had dark textured argent in the recessed groove.
Other than that mix and match! LOL
Thanks for the advice everyone. This helps alot. I'll keep hunting
I believe there is a company making repros except they are solid aluminum.
IIRC $200
They also make the trunk lid trim that's always beat up too.
The solid aluminum ones I saw were for the Plymouth version. There is a repop on Ebay right now, but I'm not sure if it's 66 or 67.
Definitely Coronet Solid was being reproduced.
