67 GTX Dim Exterior Lights
Big9crab
12:20 AM
Springboro Ohio
Have been going thru and cleaning up ground connections to improve dim headlights, taillights and rear turn signals. Have made progress in finding grounds for the headlights and have made brighter lights, however, been having trouble finding ground connections for the rear end. Have cleaned the light clips and the sockets that they go in, only minimal success. Tried LED's (not too successful) bought "upgraded bright" standard 1157 bulbs and it has helped, but looking for tips on grounds that I may be over looking.
Maybe you should back probe the sockets and get a voltage reading. You could also run a ground direct from the battery to a bulb socket or wire and see what changes.
You need to start measuring for voltage drops.
You are not very far from me..........
Taillights ground to the body with the mounting nuts. The factory nuts have barbed washers to get a good ground. Just jumper a ground to the rear sockets and see of lights get brighter.
But the real question is are you doing this with engine off?
Testing lights with engine off battery can go to low 12's or high 11 volts, not very good.
A running engine will have 14-14.5 volts going down the road above idle speed.
I have used 2357 bulbs as replacements for 1157's. They are brighter.
Thanks for the advice, I bought some 2357's and they made a marked improvement. I still want to work on some more things, but this made it much better.
I am going to work on the mounting nuts as suggested. Thanks for the advice.
Tried running a ground from the battery to the sockets, did not notice any improvement. Thanks for the suggestion.
