67 GTX Fender Emblem Placement
67gtx
11:36 PM
Kevil Kentucky
Does anyone have measurements for drilling the fender emblem holes on a 67 GTX?
Surely someone can provide some measurements? Car had sheet metal replaced years back and the emblems were in the glovebox when I bought the car.
I will have to remove an emblem to expose the mounting holes for measurement from some reference but I’ll try to do so this morning.
Here are mine but a word of caution as I know the right fender on mine was replaced by a prior owner with a Belvedere fender. It appears the GTX emblem might be a little too far back compared to the Left side which is original as far as I know. We probably need someone to measure their right fender or at least post a close up picture to compare it to. Last photo has measurements.
Right side - Note the G lines up with the second letter under Belvedere. I suspect it should line up with the left side of the "L" to center it a little better. Hopefully someone can verify on an original car.
Left side which to best of my knowledge is the original fender. Note the X lines up on the back side with the start of the 3rd letter which appears to center it a little better with the Belvedere name plate.
Dimensions - measured from rear end of fender with a tape. Also the dimension from the bottom of the Belvedere emblem is shown.
