- 5:52 PM
- Jan 29, 2018
- Midland Ontario, Canada
You said that you already unplugged the parking brake switch and your light is still on, are you not following what we're telling you to do next?So, is there anything wrong with me just unplugging the wire if I have no intention of using the parking brake?
If it mysteriously just came on, you may have a blown brake line/hose/wheel cylinder that has set off the differential switch in the distribution block. Hopefully it's just a wire insulation issue that has bared itself to ground.
