ChazRam
Good Morning, reaching out for some help from people who know these cars. We have been restoring a 68 Coronet R/T for the last couple of years. Got it up and running and driving. Having some turn signal issue.
When the turn signals are turned on the flash is fast and only blinks for a second, in other words, fast and weak. We had these working good but something happened and they do not operate like they should. Lights were all replaced awhile back and did operate correctly. Replaced all the fuses and the flasher (TWICE) and still having issues. My idea is something in the front turn signal housings is causing this as I had my brother turn the turn signals on left and right. Right flashes fast and left did nothing. Pulled on the parking lights and the left front lit up but did not flash but the right did. Thoughts were the housings are old and need replaced or there is some sort of ground not getting a connection??
Problem 2, the brake system was completely replaced. Everything is new except the rear drums which nobody makes. Everything works as it should. Brakes respond well, pedal sits where it should. Problem is the brake light switch sits up against the brake pedal arm but the pedal falls just short of pushing in the pin to turn off the brake lights. The switch is adjusted all the way down. I can pull the pedal up and it makes the switch work right but the pedal feels a bit high. Thinking a simple spring would remedy this but wondering if anybody else has had this issue and perhaps drilling different holes in the switch housing to relocate it about 3/8 of an inch lower or making a plate to lower it might be in order? Any ideas.
Thanks for any help that you can provide.
Chas.
Chas.
