68 gtx
Rob R
11:35 PM
Canada
This is my 68 GTX numbers matching car with 71000 miles on it.
Interestingly, I don't care much for a 68 runner, but I dig 68 GTXs
bad *** ride!!!.....love em!.......aint that a 69 hood?.....heres mine, since 1985.... soon to be born again
eldubb440...
I put the 69 style vents on it when I first bought the car to let the heat out. I just got use to the way it looks and never bothered to put the originals back on the car.
knew you had a good reason.......looks great either way.......im inspired
HOLY CRAP! You came to PLAY with that Dominator engine!!! Whats the specs, nice ride too!!
Very nice ride.Gotta like a good burnout when you don't have to hold the brake to light em up.
Love the 68's! I really like that color silver too.
Hey I have a 69 and I added the airgrabber screens to help let the heat out.... someday I'll get the air grabber, LOL.
Onebad...
the low deck is a 502 and has a Callies crank..coated brgs..Manley Pro Billet rods...Bartons trick tapered pins and JE's..it's 16.5 to 1..solid roller...350 cc Indy -1's that flow just under 400 cfm...on the pump with a spacer under the carb it made 830 hp and 800 ft lbs...
rolling Thunder...
it's that 68 only color M5 charcoal gray metallic.
GTXperience...
I put the original block back in for an appraisal and couldn't drive around with a 440 ...so I built a low compression 515 with K1 pieces and a 350 cfm set of EZ-1's (my son built the whole thing)...it made 730 hp and 600 ft lbs on 87...
Onebad...
rolling Thunder...
GTXperience...
Rob I see you have Manitoba plates. Would you know Farmer or Brian Scott? We also stay at Ray Markusa's place when we go up there.
T/A...
never met Farmer or Brian...I know Rays cousin Ken and talked to Ray once...
