Cletus
Here's some more rookie questions for y'all...
My Satellite does lean a bit to the right and rides kinda low, not a very "muscle car" look IMO. I'm planning to raise the rear, perhaps with lift blocks or air shocks. The front, however, is a different story. Been trying to gather info on torsion bar adjustment and got under the car to see what I could find there.
The leaning is best seen when car sits on a level floor.
View from behind. When car was parked outdoors, I first figured the leaning was in the road, leaning towards he curb.
Side view. While the attitude is kinda good, the car is way too low - I've had ground contact when riding slowly over speed bumps and paving. Those are 14" tires, btw - I believe I'll swap them for 15".
So I took a peek underneath, trying to localise the t-bar adjustment bolts. Is that the one sticking out just to the left of the middle of the pic?
If so, that would be the other one. Does it look like the right hand side bolt is sitting lower than the left? I've understood from reading the forums that the bolts needn't be sitting on egual height, but this looks like a bit too much of a difference.
Right now, I can't even get a normal jack under the k-member or even the rear axle, so placing the car on stands is not possible until I manage to raise it. Are those bolts the adjustment bolts? What other tips and advice would you offer when it comes to making the car ride higher?
(EDIT - have no idea why the pic below is there...)
