'69 B Body Alignment Specs.
mrhemi
6:48 PM
Ontario
Apologies if the query has been answered previously, however a search did not come up with the exact question.
I have just replaced the rear springs and torsion bars on my '69 Charger R/T. Will be setting the ride height to stock specs and getting an alignment done. All suspension components are stock with only about 18000 miles on them. I realize the current thinking is to get as much caster into it as you can, especially if using radial tires. Now I just noticed that the FSM manual lists a different caster spec for manual steering (-1/2 deg.) as opposed to power steering at (+3/4 deg.). I do not know what it was aligned to previously.
Is there any reason not to adjust to maximum positive caster with the manual steering? I assume the original thinking was to make it easier to armstrong the steering wheel. The car will normally be on P255/60R-15 radials on 8" rims. Occasionally will be fitted with stock F70-15 redlines.
Thanks in advance.
Radial tires? If so.....I refuse to go by the book!
Hence the question. But what about the difference between an manual and power steering box having different specs.?
I generally go with what makes the car handle better.....stock parts or not. Usually, stock parts won't give what I like but sometimes they will give what I want on some cars.
I think pretty much general consensus for a normal street driven car with radial tires. -.5 to -.75 degrees camber, 1/16” toe in and +3 or 4 degrees caster. Probably tough to get with all stock components unless you have the offset upper control arm bushings or aftermarket tubular or adjustable ones.
I rebuilt the front end on a Dart recently, with the offset UCA bushings I was able to get 7 degrees.... Car drives incredible...
NEGATIVE DEGREE caster settings? Gross.
My settings:
6* positive caster
1* negative camber
1/16 toe in
You wont get caster settings like that without aftermarket UCAs or the offset bushings, but the closer you can get to those specs the better your car will handle. It will surprise you...
My settings:
6* positive caster
1* negative camber
1/16 toe in
What would be the max positive caster you could get with a Super Bee's stock suspension (I have radial tires) and will increasing the caster by positive 2 or 3 throw out your camber and/or toe?
My settings:
6* positive caster
1* negative camber
1/16 toe in
The guy that you quoted and asked for advice made the post over 5 years ago. Myk was a cool guy but has not been on this forum for a few years now.
These cars are designed in a way that as the suspension compresses and the front gets lower, the caster drastically increases. See the chart...
The amount of caster that you can get aligned to matters a LOT on where you have the ride height set. The lower you are, the more caster you can get.
Caster aids stability. It makes the steering want to go straight and stay straight. Negative caster makes the steering want to wander and follow whatever cracks, bumps or crown the road has. In short, you never want negative caster, ever.
You want some negative camber too. Not a lot of it but some. I have 3 cars of mine here that I aligned myself and all have at least 1/2 degree of negative camber. This car....
....has aftermarket upper control arms that allowed me to get 8 degrees of POSitive caster, a full degree of negative camber and 1/8" toe in. It does not wander, it does not pull to one side, the tires are wearing normally.
To answer your last question.....
Caster will not affect tire wear. Camber won't either if it is around 1 degree or less. It is the TOE that chews up tires. Toe OUT with negative camber causes a scrubbing action on the inner edges of the tires and that wears away the tread pretty fast. Too much toe IN will wear the outer edges of the tires for the same reason.....the tires are fighting each other and scrubbing on the pavement.
You do want a very slight amount of toe IN though. The tire's (even slight) resistance to rolling pushes them rearward slightly, in effect it is toe-ing them out so a little toe in is like a "pre-load" to act against it.
Cheers....
I have power steering and radial tires so let's focus on that.
Does your car wander at freeway speeds? Good test is on a known flat highway and if you have to continually correct, it needs more caster. If you have an area where you can go faster and it still wanders a bit, add a bit more caster. You also have to pay attention to the rest of the adjustments when making any adjustments. Keep in mind that not all Mopars are the same....what works for one might not work for another.
Is this right for manual steering - negative caster? How the heck would negative caster work? Seems like it would drive like a wonky shopping cart from Walmart.
Keep in mind those specs were for bias ply tires and the more narrow crowned roads of the day. The engineers back then were trying to compensate for that.
A few weeks back before the alignment I took the car to a show where the speed limits ranged from 60 to 80 KPH but I didn't take any notice of how flat the road surface was. I have no idea on how to adjust caster and don't know if you can only play with caster if the car is on an alignment machine. If caster needs to be increased it would have to be done so the increase doesn't effect the toe or camber. The maximum legal speed limit on our Trans Canada HWY is 100KPH or 60 MPH.
Cheers....
Currently caster is at 0.3 (L) and 0.4 (R). Camber is 0.3 both sides and toe is 0.13 (L) and 0.12 (R). Per Toe Range from the sheet the guy who did the alignment 0.9 to 0.16 both sides where mine was set at 0.13 (L) and 0.12 (R). I was told to increase the caster as much as possible and keeping toe at zero.
The factory recommended caster was based on Bias Ply tire technology of the 60's.... Do you want the car to drive like it's 1968? Or would you like the car to drive more like a modern car?
Caster is basically a non-tire wearing adjustment... If you were somehow able to put 15 degrees of caster in you might see minimal tire wear but that would only occur when cornering & it would be of little concern... (only car I'm aware of running 15 degrees of caster was Mercedes)
Unmodified these cars can rarely get 2 degrees of caster, with aftermarket control arms or offset bushings 4-5 degrees is normal..
Here's the thing... It's pretty uncommon for these cars to actually wear out tires before the tires get to old to run safely...
So I run more negative camber than is recommended 1-1.2 negative camber, as much caster as your adjustment will allow & minimal toe in....
The car will be more fun to drive and it will be safer... No reason to not improve the alignment IMO..
When I see alignment specs with what I see above....
Is that total?
.16 is less than 3/16" which seems okay if your tires are wide but if that is a toe in number for each side, that seems excessive.
Is that total?
If you add the toe numbers from both sides it would come to 0.25, tires are about 7 inches wide
