RobP
First, I'm not well versed in wiring. I've had intermittent issues with the reverse lights not always working and now my inspection is overdue!
Last year I replaced the 3 pin NSS wire harness (and the reverse lights have worked since I replaced it until now)
From searching I've determined that I need continuity at the outside pins ONLY when the car is in reverse. Check.
I have continuity at the other end of the harness before it goes through the bulkhead when the car is in reverse. Check.
I have no power to the lights when in reverse and the ground is fine. Check.
I've powered the reverse lights through another power source and they both work. Check.
From those with more knowledge, what's my next step?
