inri
I'm converting my '69 RR to a Gen 3 Hemi. I've yanked the engine, transmission and gas tank. I recently purchased the efi tank with in-tank pump and new fuel float sending unit. I would like to test the float for accuracy prior to installing the tank in the car.
I have the battery located in the truck connected to a kill switch. I have removed the middle (2nd) bulkhead connector in the engine bay; it was old, corroded, but worked. I will be replacing it with a new one very soon. I don't know where to run the positive and negative battery connections now so that I can get power to the car, specifically the gauges to test the fuel sending unit. Do I need the middle bulkhead connector for this?
Right now I have the positive battery cable and negative cable dangling in the engine bay. The car used an MSD 6AL and coil with the starter relay in the prior setup. I no longer have the msd or coil, but the relay is still there.
Thanks guys!
Thanks guys!
