Beep!Beep!
finally have a painter , will be needing to install glass soon what brand and where should i buy seals from ?
70 RR, doesn't have a gasket on the rear glass. You need a tape kit, I forgot what thickness.finally have a painter , will be needing to install glass soon what brand and where should i buy seals from ?
Suppliers?70 RR, doesn't have a gasket on the rear glass. You need a tape kit, I forgot what thickness.
do you know a good supplier for both ?3/8" Butyl ribbon x 15'. Some kits come with the rubber spacer blocks for the bottom edge. Precision's rubber gasket on the windshield.
