71 -74 road runners
Thanks for the explanation about the differences between 71/72 body lines vs. 73/74 lines. A very big help! Next question then is would the 72 engine wiring harness work on the 73? I picked up a 73 U code roadrunner and it needs some work. Most urgently the wiring. thanks all. great forum.
I could be wrong but i would guess 71 to 74 wiring harness are the same but the options would be different. Lets say you can find a 71 with the same options you could use that
I have the light forward wire harness from a 1973 Plymouth Satellite.
what does "light forward" include? All the engine compartment? what condition is it in and how much are you wanting?
I appreciate the reply. I'm troubled by the fact that YEAR ONE carries 71 and 72 wiring harness, a positive cable package, but they don't carry the same for the 73 and 74.
Light forward AKA "Engine/Forward Light" means from the bulkhead (engine side) to the headlights and all related light components. ie: side markers, low beam, hi beam and parking lights.
My harness is in good condition with one defect. The defect does not interupt the performance of the harness. It's the main terminal block that plugs into the bulkhead. It has the broken plastic tabs (ears) and one of the edges is chipped but it still plugs in and functions. These terminal housings are available repop.
My price is $50.00 + shipping. I couldn't find any new ones on-line for 1973 B Body to compare but I know that the late 60s/early 70s B Body engine forward light harnesses go for $150.00 + new.
Here's a pic........
My lights all work. Based on your explanation, what I most likely need is an engine/ starting harness. Lots of odd taping and battered wiring. Thanks for your help and your input shows what a great forum this is.
Yes there are 2 main harnesses under the hood, the engine harness and the light harness. Evans wiring can make an engine harness if you cannot find one. Just specify if BB or SB.
Evans Wiring:
http://www.evanswiring.com/
