71 GTX hood release cable clip
tgc
8:33 AM
S.E. Michigan
Putting the last details on my car and just put in the hood release cable and hood latch mechanism. It looks like there should be a clip to attach the cable to the lower part of the latch. What does it look like and where can i find one?
Thank you very much! Found my stock cable in a box and found the clip. Im all set now.
Could you provide some detailed pictures of the cable routing & what hole is used in the firewall, friend of mine is putting his 72 RR back together & is uncertain,taken apart many years ago.
Sorta tough to see, touching the cable with my flat blade. Comes out of the fire wall under the master cylinder closer to the fender.
