71 plymouth roadrunner 400 stroker needs intake manifold that is same height as stock for air grabber hood.
Greg W
10:19 PM
South Bend in
Rebuilding a 400 to stroker, looking for aftermarket intake that is same height as stock because it a air grabber hood. Any info will help. Thanks. 1971 plymouth roadrunner bought new in 1971 and KEEPING.....
You have a little leeway with a b block because you can use a 440 air cleaner base plate. Use carb spacers to get the right height.
The Street Dominator is low...but I don't know if it's air grabber low. But as post 3 stated maybe it will work with a 440 base. Proven in many dyno tests the Street Dominator is the King of intakes that will fit under a hood.
Is a 69 383 Magnum intake manifold the same height as a 1971 400?
The Holley Street Dominator is 13/16" higher than a 69 383 Magnum intake. I call the 440 air grabber base 1" shorter, so it looks to me like you can make it work.
Rebuilding a 400 to stroker, looking for aftermarket intake that is same height as stock because it an air grabber hood. Any info will help. Thanks. 1971 plymouth roadrunner bought new in 1971 and KEEPING.....
Old school DP4P was an over the counter part in 70/71 that’s the aluminum version of the cast iron intake. I run a Torker Edelbrock but the air filter is a Moparperfirmance K/N and a lot shorter than the factory Fram CA305. Good clearance with my factory air grabber set up. Key was the 383/400 base and using the shorter K/N filter when using tte Torker I installed
