Hi I have a harsh 2-3 shifting issue with the 727 I just rebuilt for my 68 Charger 383. I installed a transgo tf-2 kit, 2400 stall converter, billet rear servo, sonnox accumulator, 3.8 lever and solid red lined kickdown band. All other parts are stock. The 1-2 shift is great. It's slightly firm under light throttle and gets firmer the more you keep your foot in in. However the 2-3 "bangs" every time. The shift seems quick and the rpms don't flare between gears... It's just the harshness of the shift is definitely excessive. It makes no difference if I'm accelerating very lightly or hard. I called transgo and they think I have a overlap issue. Thy said I need to install a additional spring in the kickdown servo. I have the one inner small spring in the servo. They said I should install an additional outer to release the band quicker. The manual shows the 440 and 383 HP cars only use one inner spring so I don't see why this should not work in my application as my car came with one spring from the factory. I'm thinking the band should be backed off but I already backed it off 2.5 turns from 72in lbs. Any suggestions?
