Oh sweet thanks. Was looking for an Aus supplier really hate paying for freight.Drive Line in Girraween, NSW might have an o'haul kit. If not, Summit is probably your best bet.
I don't know of any way to be sure if a torque convertor is bad, other than if it rattles, the stator broke. The material in the pan is hard to tell from the pics. Some material is pretty common. A lot, and if metallic is not good. I have never used a TCI convertor, was never impressed by them. Open up the TCI trans and see what you see. If there is a supplier that knows Mopars nearby get the rebuild kit. They are simple to work on when you know how they work. dvw gives great advice and knows his stuff, listen to him. If there is a lot of material circulating in the trans, take a close look at the internals of the valve body. That will get scored by contaminants and not function properly.So I done some digging on the part numbers on the TC and it matches a TCI Streetfighter TC. Doesn’t indicate what stall RPM it is. Is there any way to tell if the TC is toast? Or just pull it and give it a shake?
So I would have to replace that shaft just due to the small wear on the circling ring groove?View attachment 1288961 View attachment 1288962 View attachment 1288963 O.K., so you need to replace the output shaft because of the groove for the snap ring is worn axially.
Next, buy a complete set of selective thrust washers, ( about $6?) They are fiber and come in different
sizes so you can set the end play (very important). If this trans is going to be run hard, You need to
replace that front aluminum three planet with a five planet steel unit! Also, get a complete set of bronze
thrust washers for the planets. Obviously the one that used to be on that aluminum planet is junk. The
trick is to get an output shaft from a 71 or later transmission and a steel five front planet from a 48RE
diesel transmission so the planet fits the spline on the shaft. The earlier shaft has a different spline.
The second pic is of the bronze thrust washer on the back of the rear planet. The bottom picture
is a 71 and up Stator support with the wide bushing (Best choice)
Thanks. I did also find that in the other planetary set that had no wear, it had another thin metal splined disc whereas the damaged one didn’t.I agree with most of what zyzzyx said. For street car, you can use any of the stock 3 or 4 pinion planetary. I used a OEM 4 pinion behind 550-600 HP for thousands of runs. Be sure to match the front pump(early or late) to the front clutch drum(narrow bushing is early). I suspect the cause of this damage was related to drive shaft length. I can't think of any other cause that would make that type thrust damage. Check that output shaft for straightness.
Don't know any way to tell about the TC. I just know that my convertors that went away, broke the stator which was the rattle sound. Good luck
It’s the front assembly that has worn and is missing the thrust. Looks like it was meant to have a copper thrust with the tabs in it. I would say they have forgotten to put it in when they have rebuilt it. Well at least I know why it’s buggered and it hasn’t completely exploded. Now to get new parts and put them back in.The rear planet gets that thin splined washer at the rear only. The bronze thrust washer clips on the front of the planet. It thrusts forward during operation. Like I said, when everythng is assembled, you can check for end play and put the correct washers in the right place
I’m taking it to a machine shop today so he can clean it up and fit a bigger snap ring. I will check my shaft. And get back to you. Could it have anything to do with improper depth setting on the TC to engine? I’ve never installed one, just thinking out aloudThat sure seems like an improperly assembled trans. I'm still concerned about the output shaft snap ring. Why is that failed? Again, maybe a drive shaft length issue. I've been building 727's for 50 years, never seen what you have.
Ok so your saying the circlip grooves on either side of the bearing aren’t dire to the overall end play result? Would it be best just to get some new circlips and leave the shaft?As far as the snap ring groove for the governor. There normally isn't any real fore/aft force there. My feeling is that the damage was caused by the failure of the #2 thrust washer (which is uncommon). I would check the front drum to make sure the inner bushing is snug. The #1 and 2 thrust washers are phenolic resin. They are available in .061", .081", and .102" thicknesses. Common is That damage could have been caused by the drive shaft being forced into the trans. End play is controlled by the stack up of the #1, 2, and 3 thrust washers and the snap ring in the tail shaft housing retaining the output shaft roller bearing. You'll see the bearing itself can move fore/aft some. That's why I wouldn't get overly wound up about it. Just make sure it's at the lower side of the spec and isn't bound up. The The drive train (rear shaft) endplay is independent of overall endplay. It's set by the #4,5,6 thrust washers. The assembled unit will have very little endplay when measured between the output shaft snap ring and front planet. There are shims and different thickness snap rings to adjust it. But it's seldom incorrect. We run 3 pin planets in race stuff all the time. The planet splines themselves will fail before the gears. Without a trans brake at 700hp the stock planet will live a happy life. on the year not all trans get the flat splined. My 900HP racecar has an additional snap ring groove in the out put shaft as I cut down the governor and parking pawl gear to reduce weight. Its been in the car for over 760 passes. so your repair will be fine. As stated the late(71 and up) front drum and reaction shaft support is a better design. But for a street car with some strip use the early stuff works fine.
Doug
